Hi,
Can anyone suggest the best way to route the speedo cable from the gearbox connection. My cable has broken because of too tight a curve as it emerges from the front of the box. Where is the best way to route it to the front of the car.
Thanks
Speedometer Cable - Cable Vitesse - Square headed tip
- Christopher Marsden
- Gouffy56
Re: Speedometer Cable - Cable Vitesse - Square headed tip
Mine was broken too because of a tight turn at the gearbox exit (see first picture). By adding a couple of supports bolted to the gearbox, now the cable is making a soft turn which solved the issue for good.
A110 1600 SX 1977 - MG B 1971
Thank you very much for your advice and photographs.
- JyL
It's always possible to have a cable remanufactured with an extra lenght, and to cut an half-moon shape out of the rear chassis to ease the curve of the cable.
Agree with the idea of a longer cable but cutting bits out of the chassis seems somewhat drastic.
Thanks.
Thanks.
