Alpine A110 fitting new bodywork to front end
Forum dédié aux Alpine A110
Swedishengineer
I am about to cut off the front end of the bodywork to my A110 and fit a new section forward of the door hinge pillars
this includes the lower section of windscreen. see photos
the existing dashboard will be kept in place
is there anyone out there that had done this before and can offer advice
photographs would be useful
google translation
Je suis sur le point de couper l'extrémité avant de la carrosserie à mon A110 et d'installer une nouvelle section en avant des piliers de charnière de porte
cela inclut la partie inférieure du pare-brise. voir les photos
le tableau de bord existant sera maintenu en place
Y at-il quelqu'un là-bas qui avait fait cela avant et peut offrir des conseils
les photos seraient utiles
Puyraimond Jimmy
Re: Alpine A110 fitting new bodywork to front end
Hello !
I've already done this operation. It's not very difficult, you just have to make a lot of measures to ensure that the new part will fit perfectly.
I've explained the method on my other forum (it's more detailled than what I wrote on the FAR) :
http://www.forum-auto.com/automobiles-m ... 3-8085.htm
Good luck :wink:
N° 14.205
Swedishengineer
Yes I have erected a steel frame for reference and am going to do a detailed survey on another car to see how it compares.
I see you kept the windscreen section . It was my plan to replace this section also .
FastEddy
Be aware of the fact that the new body part is from a different mold (probably from a FASA or an earlier mold (beginning years of the seventies, where the old one is from a later year in the 70's.
Good luck with the transition though.
Eddy, de glöjetige Mestreechteneer
Alpine A110 1300VA (kit 1296)
Swedishengineer
latest picture with body offered up in place[img]
Swedishengineer
any advice on fitting radiator grill
JyL
Basically the 6 hooks have to be bent to 90° to receive some screw to fix the grill through the inner lip from the overture in the bodywork. It will not fit perfectly, you will not be able to use 6 point of attachment and you have to bend the grill by hand.
[attachment=0]grille nez.jpg[/attachment]
GVallerian
il s'agit d'une pièce absolument non conforme à la pièce d'origine et quasiment impossible à monter : elle est plate alors que la pièce d'origine est arrondie (et le marbre pour la fabriquer est bien arrondi) et ensuite les pattes de fixations sont non conformes à l'origine et particulièrement laides.
beaucoup de temps perdu pour la monter et à perte car le résultat final sera toujours décevant.
Swedishengineer
in translation you said :...
it is a part absolutely not in conformity with the original part and almost impossible to assemble: it is flat whereas the original part is rounded (and the marble to make it is well rounded) and then the legs fasteners are non-compliant at the origin and particularly ugly.
a lot of wasted time to mount it and at a loss because the end result will always be disappointing.
note sure what you meant by 'marbre'
Merci beaucoup . J'ai compris l'essentiel de ce que vous avez dit étant donné que je devais traduire en anglais. une certaine mise en forme semble nécessaire et une fixation différente est la meilleure option.
Many thanks . i got the gist of what you said given i had to translate into english. some shaping seems necessary and a different fixing seems the better option.
Fischer Claude
Au vu de la dernière photo, la grille semble fixée par l'intérieur, j'ai toujours cru qu'elle devait être fixée par l'exterieur :thinking: Qu'en est-il vraiment? quel est le montage d'origine ? Sur ma SX, elle est fixée par l'extérieur depuis que je l'ai, mais est-ce le montage d'origine??
PepeSX
Pour par l'intérieur , je pense que même avec des mains de sage femme passer devant le radiateur en place c'est chaud
GVallerian
le montage d'origine de 1963 à 1977 est la fixation et le montage par l'extérieur de la grille
Fischer Claude
Ouf, ca me rassure, j'ai eu peur d'avoir acheté une "merguez" il y a 36 ans :mrgreen: :mrgreen:
Sérieusement, c'est bien ce qui me semblait, je ne voyais pas comment monter cette grille avec le radiateur, le cache et tout le tremblement en place. :wall:
Amic'Alpinement :hello:
