Top Dead Centre on 1600 engine
- Christopher Marsden
Can anyone please tell me which of the two marks on my flywheel I should use to get No. 1 cylinder to Top Dead Centre, left one or the right one?
Re: Top Dead Centre on 1600 engine
With a screw driver in plug hole 1 or 4 you can tell and align with the clutch case marking.
If i had to guess i'd say the right one because the left one could be for the static advance ignition timing (5 to 10° usually).
Many thanks I will try that and see what happens.
regards
regards
- Gordi94
Ce volant moteur à double index était principalement installé sur les 807-12 et 844-12, il comporte un repère PMH et un repère 8° d'avance.
Il permet le calage au ralenti de l'avance centrifuge sans lampe à déphasage, il suffit pour cela d'aligner le repère 8° du volant sur le repère 8° de la cloche de boite, on obtient les 16° nécessaire au ralenti (1000 à 1100tr/mn suivant les MR et RTA) avec une courbe R267 ou R278.
Vue sous cet angle le moteur tourne dans le sens anti horaire, le PMH se trouve le plus à droite (merci PHL).
GORDI94
GORDI94
This is very interesting, thank you.
Regards
Regards
Further to your reply my distributor is the 4266 with the R234 curve, as stated in the MR Type A110. I have just had it converted to 123ignition due to wear in the shaft and problems with the bob weights and springs. It has been programmed with the R.234 curve. I understand that the R267 and R278 refer to the A310VE and A310VF models respectively?
regards,
regards,
The 123 is perfect and honestly the difference between these curves is practically NIL!
The only serious parameter to watch is:
no more than 32° (34?) maximum advance.
