Looking refurbishment of the expansion bottle
One pipe has come loose and need soldering in
The other was rusted away and need replacing
I am wary of using a lot of heat to solder the pipes back in as I am not aware whether the cap contains anything that could be affected by heat
Does anyone know ?
Recherche de rénovation du vase d'expansion
Un tuyau s'est détaché et a besoin d'être soudé
L'autre était rouillé et doit être remplacé
Je crains d'utiliser beaucoup de chaleur pour souder les tuyaux car je ne sais pas si le capuchon contient quelque chose qui pourrait être affecté par la chaleur
Est-ce que quelqu'un sait ?
Bouteille d'expansion
- Swedishengineer
- JyL
Re: Bouteille d'expansion
Hi Pete, just trust your supplier who has good second hand units
- Swedishengineer
I always trust my supplier
but it seemed like an easy fix.
but he did not answer the question
There is a spring inside, not too sensitive to heat therefore.
There are different pressure references, you can measure your's using compressed air.
Or better, buy a new one of known pressure.
- Swedishengineer
so what should the pressure be??
do the markings on the top give an indication of the pressure
Regards
Regards
Ebullition eau à T° sous P bars : P = (T/100)**4 //Approximate formula to compute the temperature of water boiling T under pressure P.
Exemples: 2b/120°C 1.6b/110°C
Théorie: Vase expansion bouchon blanc 0.7b, vert 1b, Marron 1.2b, bleu 1.4b +/- 7%
But ignore these markings, you have to check the release pressure by yourself by blowing air in the bottle.
Anything around 1.5b will do.
- Ove
It seems that the given 'coloured data' are for the caps of the plastic version of the expansion reservoir but not the one made of glas.
N'est-ce pas ?
N'est-ce pas ?
1600VE de '72
You are right Ove, no color code on metallic caps
A good reason to measure it oneself...
- JMD
Bonjour a tous
Swedishengineer si tu ne trouve pas de solution pour ta capsule métallique de vase d'expansion en verre ,j'ai un solution en stock et de plus neuf .
Bonne journée
jmd
Bonne journée
jmd
