Can anyone provide me with a simple wiring diagram to enable all four headlights to flash. Thinking of mounting a dashboard toggle switch to operate the arrangement.
Thanks
Wiring diagram for headlight flashing
- Christopher Marsden
- Gouffy56
Re: Wiring diagram for headlight flashing
May be you could try just wiring the warning switch to the headlights relays?
A110 1600 SX 1977 - MG B 1971
- JLouis42
Je ne pense pas que ce soit ce qu'il souhaite.
Il cherche à pouvoir faire des appels de phares avec les 4 phares (principaux +LP) en installant un inter à impulsion supplémentaire au TdB.
C'est simple sauf qu'il faut prévoir des diodes dans le circuit de commande des relais de phare (s'il existe) et de LP pour que cette fonction supplémentaire ne perturbe pas le fonctionnement de série.
I'm to lazzy to make this in English, I assume Google Translate will do.
Thank you both very much for the advice.
It sounds complicated having to use diodes, etc., I probably need to get help from an auto electrician
- JLouis42
Your auto-electrician will certainly make something similar to the attached diagram, diodes are not that complicated!
The addition are coloured in green.
Any diode like 1N4007 will do........................
- MBriand
I think there is a possibility to make it using a two poles switch, instead of single contact + 2 diodes...I am not electrician, but I think the following schematic can work (I made it from the schematic that I have for my car, which is using relays for the front lights...can be done without relays). The aim being to avoid disturbing the basing functions by recirculation between the different wires.
As I mentionned at bottom of the first schematic, there is also a possibility to do it using 2 relays instead of the 2 diodes...(but again more complicate...)
