FASA moteur d'essuie glace
Forum dédié aux Alpine A110
Swedishengineer
J'ai FASA A110 avec un moteur d'essuie-glace FEMSA
en travaux mais le mécanisme de fermeture ne fonctionne pas.
Joindre des photos des internes
quelqu'un aurait-il un schéma électrique du mécanisme
windscreen wiper motor
(I have FASA A110 with a FEMSA wiper motor
in works but the closure mechanism does not work.
Attached photos of internals
has anyone got a wiring diagram for the mechanism)
MBriand
Re: FASA moteur d'essuie glace
Si la question concerne le branchement du moteur essuis-glace, le sujet suivant peut éventuellement contenir des informations utiles:
sujet: "Raccordement moteur essuis-glace A110 (FASA 1974)"
Swedishengineer
wiring diagram of whati have
need to connect the cam terminals to system
any ideas
MBriand
I don't know if you had a look to the item that I mentioned yesterday, about same subject...
I was not the guy who removed this harness from the car...I had just to find how to reconnect the new one...this was the aim of my questions in our forum at that time.
In this item, I posted the only wiper motor diagram that I have for this Femsa motor. I made it by analyzing the connections of the switches and wires existing on the old harness.
I guess that the cam terminals that you mention are related to the automatic return to initial position? what I can suggest is that you can maybe find more information into wiring diagrams of other cars that have been using Femsa motors: I have seen at least one used by Lancia at that time
Swedishengineer
I could not find anything form your suggested search title only my entry
can you give me more details on the link
thanks
MBriand
Swedishengineer a écrit : 19-janv.-2022 18:52 I could not find anything form your suggested search title only my entry
thanks
I don't know how to make a link to other subjects...(I see sometimes other guys doing it...but I don't know the procedure...)
But anyway, if you come back to the level "Alpine A110", just type in the search window : "Raccordement moteur essuis-glace A110 (FASA 1974)", or part of this text, it will show you your subject, but also below the subject that I created 2 years ago
Swedishengineer
I managed to find some as suggested but am more confused
the way to put a specific link in is just to copy from the address bar at the top
thanks
Swedishengineer
i have added picture o f switched to show how connected
Swedishengineer
I have concluded that the switch is the wrong one
I need a two way wiper switch with park
