A110 FASA soupape de chauffage (heater valve)
Forum dédié aux Alpine A110
Swedishengineer
Anyone know how that heater valve is supported
Quelqu'un sait comment cette vanne de chauffage est prise en charge
Mine has a bend in it . others I have seen are straight
Le mien a un coude. d'autres que j'ai vus sont hétéros
Avenir13
Re: A110 FASA soupape de chauffage (heater valve)
Some trick from Google Translate :wall:
You just said that "Others... are heterosexual" :lol: :lol: :lol:
Hopefully yours (?) is bended :lol: :lol: :lol:
Apart from that, my system is different (cable actuated - without bad interpretation, guys !) so I cannot help.
A110 gordinisée (1296)
Swedishengineer
send a picture of your under the dashboard
envoie une photo de toi sous le tableau de bord
Avenir13
Here is my heater control (faucet is moved by a cable):
You may notice that I added a connection with a short copper pipe (not visible) and 2 clamps on the return line (so has to dismount the heater "easily" ; however, some will argue that it creates additional source of leakage).
On the front (partly masking the faucet) is a large gauge cable for the battery switch (nothing to do with heater!)
GVallerian
Exactly the same mounting in my 73' V85
Coco
GVallerian a écrit : 24-oct.-2022 18:00 Resized_20221024_172147.jpg
Provenance Renault R6 je crois…
Swedishengineer
These detailed pictures are what i am looking for the ones showing a rod connected to the valve
but can you take some showing the rest of the rod that actuates the valve to see how it is supported
One of the pictures shows the valve with a cable operation. I did not know that type of operation existed
GVallerian
the valve with a cable come from R8, this mounting exist on the berlinettes before end of 1970 with command of heater from R8.
after this date, the valve come from R6 and the command from R12, like on your car.
picture in one moment, I must go under the house to made it!
GVallerian
I change the car and use the seats of Nicolas and Vial for the pictures, it is the ex-work car of them in Rallye Monte carlo 1973...
Swedishengineer
many thanks for the help but other members
it is all becoming cleared
All the pictures and the manuals see to show a straight rod working the valve
ON my car the rod has a kink in it
I see from the posts there were different versions fitted to R8 R12 and R6
Mine is a A110 FASA 1972
I dare say i could make a straight tube but what i am missing is the piece ringed in the photo I think it is plastic
Has anyone got a spare one or can give me the measurements to make one
Swedishengineer
I now attach a couple of photos of the parts i have
with the valve rod a curved
anyone got any idea if that could be connect for my car a FAS 1300 1972
Je joins maintenant quelques photos des pièces que j'ai
avec la tige de soupape incurvée
quelqu'un a une idée si cela pourrait être connecté pour ma voiture un FAS 1300 1972
Thanks in advance
GVallerian
All parts of heater valve and command in french car. The plastic valve have not the alpine extension of Rod
Swedishengineer
has anyone seen the type of valve rod with the kink in
GVallerian
I have seen tthis model for sale in spain, it comes from spain R6 I think
Coco
GVallerian a écrit : 27-oct.-2022 09:55 I have seen tthis model for sale in spain, it comes from spain R6 I think
Je confirme…. J’en avais acheté tout un lot il y a quelques années.…
Swedishengineer
I can make a substitute rod in aluminium
The black plastic bracket is more problematical.
If possible do you have the dimensions of the black plastic piece
and the length of the rod
and is the black sleeve also plastic??
Translated
Je peux faire une tige de remplacement en aluminium
Le support en plastique noir est plus problématique.
Si possible avez-vous les dimensions de la pièce en plastique noir
et la longueur de la tige
et le manchon noir est-il aussi en plastique ??
GVallerian
for the rod : 266 mm, valve to the end of rod.
plastic sheet : very difficult for the dimensions, I think it is necessary to made this part with 3D because it is impossible to find
black sleeve is metalic
Swedishengineer
Few more questions
just bought some Aluminium road 8mm dia
My kinked rod had a groove in it ( FOR A CIRCLIP)
does your straight rod have any grooves
It has flattened ends at handle end and hole at the valve end (I assume yours is the same
The tube ( metal) Is this steel or aluminium I assume 8mm internal and about 10mm external
where does this fit in the assembly ?? in the plastic bit or the bracket
translate
Quelques questions supplémentaires
je viens d'acheter de l'Aluminium road 8mm dia
Ma tige pliée avait une rainure (POUR UN CIRCLIP)
ta tige droite a-t-elle des rainures
Il a des extrémités aplaties à l'extrémité de la poignée et un trou à l'extrémité de la valve (je suppose que le vôtre est le même
Le tube (métal) est-il en acier ou en aluminium, je suppose 8 mm interne et environ 10 mm externe
ça rentre où dans le montage ?? dans le foret en plastique ou le support
Swedishengineer
CAN I BEG A FURTHER INDULGANCE
can you provide these dimensions
I guess width 30mm ?? length 70mm/??
bolt dia 8mm???
i am gointg to try and make one out of 30x30 RH S ection
already bought 8mm rod but a bit oversize
and 8mm steel tube a bit undersize
so trying to cobble them together
wish me luck
PUIS-JE DEMANDER UNE AUTRE INDULGANCE
pouvez-vous fournir ces dimensions
je suppose largeur 30mm ?? longueur 70mm/??
boulon diamètre 8mm ???
je vais essayer d'en faire un sur la section 30x30 RH
déjà acheté une tige de 8 mm mais un peu surdimensionnée
et tube en acier de 8 mm un peu sous-dimensionné
donc essayer de les bricoler
souhaite moi bonne chance
GVallerian
bolt 6mm
length overal 60,4 mm
width overal 25mm
steel tube int 8mm ext 10
aluminium rod has flattened ends at handle end and hole at the valve end
